Signal Conditioning
SCXI 1581 Channel Iconstant = 78uA
Can I further diagnose a SCXI-1581 channel with an incorrect Iconstant value or must the board be returned to NI for repair?  One channel measures 78uA dc directly at the connector pins with no other connections made.  All the other channels measure correctly at 100uA dc.
(5,771 Views)
Hello ATI_TechStaff,
Unfortunately, will the current being providied so far out of specification, you will need to send the board to NI for repair.  You can give us a call and we will help you get everything set up for the repair.  If you want to talk to someone about anything else you can do, just ask to speak to an Applications Engineer about your device. (800) 531-5066
ColeR
Field Engineer
(5,743 Views)
