Signal Conditioning
Selected wrong thermocouple type
Dear all,
I erroneously selected the type J thermocouple instead of type K when using the NI USB-TC01. I would really be happy, if anyone could tell me, how I can now calculate the correct temperature from my measurement data?
(6,371 Views)
Step 1: Google "type j thermocouple characteristic".
Step 2: Find this amazing reference document: https://www.omega.com/temperature/Z/pdf/z021-032.pdf
Step 3: Find the polynomial terms for a J type and a K in Table 4 on page Z26
Step 4: Derive the original sensor voltage using the J terms and recalculate the temperature using the K terms.
I do not know whether the cold junction compensation needs to be looked at as well.
(6,365 Views)
That's my main problem: Which temperature is assumed for the cold junction?
(6,342 Views)
all TC conversion polynomes are already available in LV 🙂
And shure, you need at least a good guess of your CJC temperature 😄
I added a vi to correct and get an idea how big the error due to wrong CJC migth be.
Greetings from Germany
Henrik
LV since v3.1
(6,324 Views)
Vielen Dank, Henrik!
Meanwhile I found, that there is a temperature sensor inside the NI USB-TC01 measuring the cold junction temperature to compensate it. And it seems like the electronics around the cold junction create a quite stationary temperature somewhere at 32°C after some warm-up time.
(6,321 Views)
