Signal Conditioning
Selecting SCXI-1122 channels in the Test Panels
All 16 SCXI-1122 channels are multiplexed to channel 0.  Is there a way in the Test Panels in MAX to select a specific channel of a SCXI-1122 card in SCXI-1000 chassis so that voltage appears in the test panel?
Message Edited by paryani on 08-25-2007 02:52 PM
(5,483 Views)
Paryani,
Look at the attached screenshot.  It shows where in the test panel you can select an individual channel and see the voltage.
Alex A.
(5,474 Views)
I have a traditional DaqCard and do not see those options.  I am assuming that I can not view these channels with the traditional Daqcard
(5,474 Views)
What DAQ card are you using with the chassis?  Many old cards are still supported in DAQmx, which you could download and use for free Smiley Wink
Alex A.
(5,469 Views)
You are correct in that Traditional DAQ does not have test panels when you click on the device name with SCXI.  However, you can right then click on Data Neighborhood--> Create New..--> Traditional NI-DAQ Virtual Channel.  You can select your device and channel and use the test panels here once you have made the virtual channel.
Message Edited by Alex A. on 08-28-2007 08:09 AM
Alex A.
(5,465 Views)
