Signal Conditioning
Sending analog signals using SCXI bus to SCXI-1600 for digitizing
I want to measure a signal generated in the SCXI-1181 custom bread board module.
Is it possible to send the signal using SCXI bus to SCXI-1600.
The signal is less than +5V & is positive.
Is it possible to use AB0+ & ABO- in SCXI bus for this purpose?
I have a SCXI-1001 chassis installed with SCXI-1600 in slot 1 & SCXI-1181 in slot 2.
I have 4 more switch modules (SCXI-1160s) installed from slot 3 to 6.
Will the above has an interference when you want to control the switches?
(3,474 Views)
see here:
http://forums.ni.com/ni/board/message?board.id=250&message.id=20644
(3,446 Views)
