08-13-2009 08:40 AM
Hi all,
If you have the signal conditioning circuit that is applicable to all types of thermocouples , then send me its link. I am making DAQ card which has a 10 bit ADC. The signal conditioning should be perfect enough that the output voltage from
the signal conditioning circuit is in the range of 0 - 5 volts that can be applied to ADC. The input of the signal conditioning
circuit for my application is -10mV to + 80mV. I also read the NI tutorials for signal conditioning of thermocouples, that
also helped me but i want signal conditioning circuit with its explanation.
Waiting for your useful reply.
08-14-2009 09:55 AM
Hey,
I noticed on your other post you were pointed to Omega's website. That is probably a great place to start. I did some google searching and found a few other possibly useful links for you.
http://www.edaboard.com/ftopic67377.html
http://zone.ni.com/devzone/cda/tut/p/id/4802
http://forums.ni.com/ni/board/message?board.id=170&thread.id=432465
In the future, please don't double post, it makes it harder for everyone to find what they are looking for when issues are posted twice.
08-14-2009 10:08 AM
Alain S wrote:ALL TYPES of thermocouple will be hard to find unless you buy a converter from Omega or Phoenix Contact
But you may start with AD594 or MAX 6675
Is this also for your PIC 18F..... project?
If yes I think you better off with raw IC isn't it?
If the links don't work here, go to the other thread 🙂
08-14-2009 10:17 AM
08-14-2009 02:35 PM
My problem is still unsolved if i reduce my requirement from all types of thermocouples to just J,K,E,R,N,B,S and T ,
then is there any signal conditioning circuit ? I dont want to use any cold junction IC . I will measure the temperature of hot junction from thermocouple and the temperature of cold junction from thermistor or RTD. The rest of the calculation , i will handle in labview.
My requirements are mentioned above. IS THERE ANY CIRCUIT ? simple signal conditioning circuit but efficient?
Thanks for all your replies .
08-14-2009 02:56 PM - edited 08-14-2009 03:01 PM
muzammil_IIEE wrote:My requirements are mentioned above. IS THERE ANY CIRCUIT ? simple signal conditioning circuit but efficient?
Dear Muzammil Saleem
Your Google is as good as mine. If some people in this forum have circuit they will give you some clues. But if not, I guess you have to come up your own idea for this project. It is perhaps why you did get this assignment 😉 Is this some kind of educational assignment?
Edit: And one more thing. This forum is much like girls. If you get to pushy, it will get suspicious about your intention and turn the back on you. Just a friendly tip
08-14-2009 04:46 PM
Lets see:
I open my Omega catalog, turn to the transmitter section selection guide and in 1 minute I find the TX62 and TX64 that does J, K, T, E, R, S, B, and N. has a 4-20mA output that can be scaled to a 1-5V output via a precision 250 ohm resistor. Also does RTD.
-AK2DM
08-14-2009 05:11 PM
And I might add that there are scores of temperature controllers available from many manufacturers that can handle more than the 8 type of T/C's you listed with analog outputs for the process variable.
-AK2DM
08-15-2009 02:24 AM
muzammil_IIEE wrote:My problem is still unsolved if i reduce my requirement from all types of thermocouples to just J,K,E,R,N,B,S and T ,then is there any signal conditioning circuit ?
Wow! Wikipedia tell me about 10 types of TC, you asked for 8, that's still ALL for me! Should I
or should I
I don't want to use any cold junction IC . I will measure the temperature of hot junction from thermocouple and the temperature of cold junction from thermistor or RTD. The rest of the calculation , i will handle in labview.
You know where to measure the cold junction temperature? Ok then I won't elaborate 🙂
You can start with a TX62 like AK2DM suggested, but @315$ it's maybe too expensive ![]()
The TXDIN70 I suggested from the same Omega brand starts @85$ ![]()
Basically you don't need any circuit!
With the correct NI DAQ card, just read in the voltage and convert it yourself to a temperature using polynomial or lookup table.
But of course if it's for your PIC 18f4550 DAQ project, you can't use a NI DAQ card, right?
So just amplify the TC voltage with a precise amplifier IC, read that voltage in the PIC, send it through USB to the PC with the LV application and here again use a polynomial or lookup table to convert that amplified voltage to temperature.
If it's for your PIC based DAQ project I would go this way, but who am I
You see plenty of possibilities, but since we don't know the whole picture it's hard to point out the correct/perfect solution.
08-15-2009 04:26 AM
