Signal Conditioning
Signal routing using SC-2345 with SCC-LP03
I have a SC-2345 module carrier which I intend to connect to my Daq-card 6036E. The goal is to filter some of my signals in this carrier using the SCC-LP03 module.
Q1: Is each slot (J1, J2,  .. J8) equivalent/connected to the differential analog inputs (Ch0, Ch1, ..Ch7) in the Daq-card itself?
Q2: Using the LP03 you've got 2 inputs for each module. I assume that a analog diff signal connected to terminal 3 & 4 in the LP-module would end up in the channel that the module is connected to (J1 = Ch0), but what about the signal coming in via terminal 1 & 2? In which Daq-card channel will that signal end up?
Q3: I understand that you can connect dual stage modules so that two modules "in series" can condition 1 signal, by using slot J9 with module 1 (cable input in this module), and slot J1 for module 2. This would in the end get the double-conditioned signal to end up in analog input channel no 1 in the Daq-card, right?
Thanks in advance,
Johannes
Message 1 of 1
(3,910 Views)
