Signal Conditioning
Is the pc1 - 6251 card compatible with scxi 1000
My scx1 -1000 module with scxi 1303 in slot 1 will not communicate with the M series pci 6251 card . I am running Labview8 in windows xp.
(4,157 Views)
PCI/PXI ( Express versions too) 6251 cards are compatible with SCXI signal conditioning
USB 6251 is not compatible with SCXI
Have you configured/assigned  your SCXI chassis to The DAQ card correctly in MAX??
Hope this helps
Dev
Message Edited by devchander on 10-26-2006 04:49 AM
(4,149 Views)
Thank you for responding.The following is the procedure I used in Max& measure along with the messages given.
In NI-DAQmx Devices i created new device scxi-1000
Chassis Communicator NI PCI-6251
Communicating SCXI Module slot 1
Chassis adress 0
auto detect modules box ticked
saved
Message in scxi chassis config window "Chassis is empty.click the modules tab and insert a module"
so i manually inserted the following:-  module array scxi- 1102
                                                             accessory scxi -1303
Then in the window for scxi 1303 in  the tab for cabling "which device connecting" i put pci-6251 and the same for module digitiser.It is obvious that the chassis & modules are unable to be detected automatically.On completing config. i return to the main configuration window and right click on the scxi-1102 "scimod1" go to test panels press start and the following message appears :-
error -200073
scxi module specified in hardware config was not found.
(4,138 Views)
Read this link and see if it helps
also this link
(4,120 Views)
