Signal Conditioning
Using same excitation on several channels
Is it possible to use the excitation voltage from one channel, as an external voltage on three other channels?
So that all stain gauges is using the same Vex
Using following equipment: SCXI 1520, with SCXI 1314 terminal block.
Lars
(3,596 Views)
Why do you want to do that??
Especially  when you have an individual excitation source for each channel??
(3,586 Views)
it´s because we have 4 strain gauge mounted on a "ring"
To minimize the amout of wires from the "ring", i am using the same excitation for all SG
(3,583 Views)
