Signal Conditioning
Smallest force/weight that can be measured ?
Hello everyone, so i am newbie at this whole signal measuring thing.  I want to ask several question. Assume i want to measure force / weight using honeywell model 31 load cell that has some spec :
  • Sensitivity : 20 mv/v
  • Load range : 500 g
  • Excitation: 5 Vdc
And connect it with NI-9237, so
My question is :
  • What is resolution or smallest weight/force that can be measured by this system ?
  • It is said in spec that NI-9237 has built-in amplifier and +-25 mv/v input range, is that means that my load cell output will be amplified from +-20 mv/v to +-25 mv/v ?
Thanks.
(1,934 Views)
Hook it up and do measurements.
Your limitations will be drift, hystereses, noise , ... acceleration, air turbulences,,,  🙂
Greetings from Germany
Henrik
LV since v3.1
(1,891 Views)
Yeah thanks for your response, unfortunately i don't have the product yet (load cell, Ni-9949, Ni-9237) because i want to make sure first before buy those product.
I see that in the load cell datasheet, its resolution is infinite (because analog signal i guess(?)), so i assume to look the digital resolution of the NI-9237. From my understanding
  • If my understanding of ni-9237 will amplify output from +-20 mv/v to +-25 mv/v correct, does it mean the ideal resolution is just calculate (1000 gram / 2^24) ?
  • Or the +-25 mv/v input range is actually just mean the range load cell output that ni 9237 accept (so output of +- 20 mv/v is acceptable to feed to ADC)
Is this correct ?
(1,882 Views)
