Signal Conditioning
Start Trigger Edge Error
Hi all,
I have a problem with some rather basic program where I'd like to generate a waveform when a start trigger occurs.
However, while setting up a start trigger, properties of the task go fully blank and it's impossible to re-assign parameters to them. Here's how I set up the initial parameters:
createAOVoltageChan();
cfgSampClkTiming();
cfgOutputBuffer();
set('writeRegenMode', 'DAQmx_Val_AllowRegen')
and until now, Task properties are saved. But when I execute function cfgDigEdgeStartTrig(TriggerSource, TriggerEdge), task parameters such as the clock source and sampling methods disappear from the task object.
I am using a wrapper&DAQmx in matlab, on a X-series USB-6363 device.
Please let me know if you have any ideas how to debug this! Thanks
(1,792 Views)
So as I understand the programming environment is Matlab. Am I right?
I don't understand following part:
... properties of the task go fully blank ...
Where it goes blank? Are there any screenshots?
__________________________________________
The best way to thank, is to give KUDOS
(1,733 Views)
