Signal Conditioning
problem with a new PCI 6281 card
I've bought a new PCI 6281 card because the old one didn't work anymore.
The system measurement is  as follow :
I send a sine signal (20 mVpp - 5Hz) to a vibrating sensor and I measure the response of the sensor. I use a PCI 6281 connected to a SC2345 and Ni max.
I have installed the new PCI6281 card with the drivers updated.
Under Ni max I send the sine signal to the sensor and I read the response. With the old PCI card there was no pb, I could see the sine signal on the test pannel, with the new one I see a line at 10 V.
Is there something to do before using a new PCI card ?
Thanks for your help.
Idetec.
Message 1 of 1
(1,285 Views)
