Signal Conditioning
Torsional vibration spectrum analysis
I’m currently doing this kind of acquisition:
Using a 360 top digital tacho
Recording for 10 revolution (3600 samples)
t & dt is a result of period acquisition measurement with PCI card
I’m a bit lost with .dat and .ddt files in order to use the samples code
I would like to perform the analysis of order spectrum, waterfall etc…
Thanks a lot for helps
(990 Views)
You attached a TDMS file, where does the dat and ddt files come into picture?
Do you have the software to analyze the data from the TDMS file?
Santhosh
Soliton Technologies
(965 Views)
Check out NI DIAdem, it has several analysis, visualization and reporting features for Mechanical engineering.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x14vCAA&l=en-US
https://www.ni.com/docs/en-US/bundle/diadem/page/exploff/examples/expl_rotatingshaftanalysis.htm
Santhosh
(963 Views)
I was expecting doing the analysis with labview from the original waveform, From the sound & vibration toolkit sample or vi looks to work only with analog or digital tacho signal. I don't know how to convert it, in order to perfor the analysis.
thanks
(956 Views)
thanks
You are missing a lot of important information to provide proper suggestion like that you use Sound & Vibration Toolkit with LabVIEW and which exact example are you referring to?
Santhosh
(945 Views)
Sorry to be unclear,
I would lik to perform with labview some analysis such as the one in the below sample.
I 'm almost sure that I have all the data's (.tdms in 1st post) but I dont know how to convert my RPM profile waveform in tacho file.
Thanks a lot
(940 Views)
