Signal Conditioning
Transfer audio signal to LINE-OUT connector
Hi all, Is there any way to transfer the audio signal which is generated by means of a Built-in speaker on the motherboard to the Line-Out connector? Baiscally, i want to acquire the voltage signal and view it on the oscilloscope. But the problem is that the signal is not on the " LINE-OUT Connector ", it is on the buit-in speaker on the motherboard. Any help will be greatly appreciated.
(5,848 Views)
Are you using LabVIEW or other National Instruments products to acquire or analyze this signal or are you simply wanting to pass the sounds generated from the on-board speaker to the line-out connector?
Thank you,
Justin
Justin
Product Support Engineer - Conditioned Measurements
(5,839 Views)
"Sounds" like a "muted" response 🙂
-AK2DM
(5,806 Views)
