Signal Conditioning
Trying to find replacements for our system
All, our system that we are currently using has been obsoleted. I have been looking for the cDAQ replacements for our current I/O modules so we can update our system; however, I could not find them listed on the obsolescence chart. If anyone could help, I would greatly appreciate it. The models are listed below:
SCXI-1303
SCXI-1321
SCXI-1324
SCXI-1325
SCXI-1326
(2,781 Views)
SCXI-1303
SCXI-1321
SCXI-1324
SCXI-1325
SCXI-1326
If you are you looking to replace those terminal blocks with something current, you need to look for the module those terminal blocks are connected to.  The SCXI-1303 guide says:
This guide describes how to install and use the SCXI-1303 terminal block
with SCXI-1102, SCXI-1102B, SCXI-1102C, and SCXI-1100 modules.
So look for the module (1102 or whatever you have) in the following link and look at the replacement options associated with it.
https://www.ni.com/en/support/documentation/supplemental/17/obsolescence-planning-for-several-legacy...
(2,719 Views)
Thank you for the link; however, the modules I am looking for are not listed there (I did check there first). I am currently looking into what is attached to the modules and looking into which modules I think will be the best replacement. I was just looking to see if anyone had any knowledge of what the best replacements might be or had experience with changing them out.
(2,703 Views)
You did not list what modules you are looking for, you listed terminal blocks that can fit different modules.  So without knowing what modules you are using how can anyone recommend the best replacements?
The example in my 1st reply was for the SCXI-1303 (Terminal block) you listed.  It can be used with the following MODULES:  SCXI-1102, SCXI-1102B, SCXI-1102C, and SCXI-1100 modules.
If you look at the link in my 1st email and find the SCXI MODULE, lets say the SCXI-1102 which can use the SCXI-1103 TERMINAL BLOCK, it will give the recommended C series model depending on if you are measuring thermocouples, current, voltage or RTD's.
You can find the module by looking in MAX or remove the terminal block from the SCXI chassis and then you can see the module number towards the bottom.
I think you are confusing the terminal block with the module.  If you are still having issues you can always call NI and talk to their sales to figure out what you might need.
(2,689 Views)
