Signal Conditioning
size of output by ADC is different from the calculated one
Hello!
I am using NI PXIe-5641R Transciever. I am using 100 MSPS from the clock as my sample rate and a decimation of 4. I am saving the output from the instrument to a file using a timer. What I am getting is the size of the file is very less compared to the calculation i make according to the decimation and the sample rate.
What can be the problems and its expected solution?
(2,257 Views)
@priyabrata215403 wrote:
...the size of the file is very less compared to the calculation i make
So ??
SizE?
Numbers??
calculation?
My answer is 42!
(Almost friday :D)
Greetings from Germany
Henrik
LV since v3.1
(2,224 Views)
