Signal Conditioning
Why does my PCI-6070E not read the probe signals?
Hi, I'm writing the RLP code for PCI-6070E A/D board. I followed the example code and get a good result when I connect a signal, which is generated from a signal generator, to any channel of the board. The weird thing is when I connect the probe signal to any channel, nothing is read. It seems like there is no signal at all.
I'm thinking that maybe the signal from the probes is "too weak", although it can be measured with a meter. All the channels are connected with a B&C connector (2010?) box, which is connected to the board. I measured the input of the board (the B&C connectors), there's a 1.167 V. Should it be 0 V?
We had Labview code before and it worked, so I'm thinking that maybe there is configuration of the board I should do? Or something else?
flofish
(3,175 Views)
Never mind this problem. It's solved by simply switching the mode from "RSE" to "Differential".
flofish
(3,171 Views)
