Signal Conditioning
Will Analog Instruments ADXL330 triaxial accelerometer work with the SCXI-1531 input module?
I have an SCXI-1001 chassis and will soon be purchasing an accelerometer input module (SCXI-1531).  I'm also investigating possible accelerometers to buy.  Does anyone know if the the Analog Instruments ADXL330 accelerometer can be made to work with the SCXI-1531?  Here is a link to the Analog Instrument's page about the device:
http://www.analog.com/en/sensors/inertial-sensors/adxl330/products/product.html
Thanks!
(6,379 Views)
The output voltage and current levels are within specification of the module, the only concern I have is interfacing between the IC chip and the BNC connections on the 1531.  If you have a way to effectively connect the pins to BNC connectors and connect that to the module, then it should work.  Are you using the module's excitation source as well?
Kyle A.
Senior Applications Engineer
(6,357 Views)
