Signal Conditioning
automatic Wheatstone bridge ?
You can accomplish the "adjustable" wheatstone bridge by a few other ways, also.
One is to use a transconductane amplifier in a voltage controlled resistor config.
Another is to use a mosfet as a variable resistor.
So, is this harmonic changing? If not, why not just use a notch filter?
Message Edited by Larry Morgan on 06-16-2009 04:55 PM
Larry Morgan
Senior Hardware Engineer
Message 11 of 13
(3,553 Views)
hi
i don't know how to make the "transconductance.." etc; can you give some references ?
(the frequency does change, it is selected by the user)
thanks
Message 12 of 13
(3,547 Views)
LM13700
The LM13700 operational transconductance amplifier datasheet has some application notes that
give some info on building a voltage controlled resistor.
Just wondering, have you done much research to see if the adjustable bridge is the ideal
solution to your problem? There's a good probability that you can dig up an adjustable
filter, or at least a schematic for one that may be simpler to make.
Message Edited by Larry Morgan on 06-17-2009 11:19 AM
Larry Morgan
Message 13 of 13
(3,542 Views)
