Signal Conditioning
build ECG signal from statescope
Do to movement artifact, it is hard to get ECG signal from the ECG sensor which being attached to human body. So I planned to build the ECG signal from the statescope. That`s mean from the sound I get from the statescope, we build the signal. Any suggestion NI technology can I apply to do so?
(6,995 Views)
the problem of artifacts seems to be solved/reduced by using some(?) more electrodes and calculations (analog or after ADC) IIRC an app note from NS,Linear or TI described a solution ..
Why do you espect less noise via a microphone?
Which of the ECG data do you expect to extract from the heart beat sound?
I'm not a cardiologist but I remember that most of the information is buried in the QRST(UV...?) timing...  Good luck !
Message Edited by Henrik Volkers on 08-05-2008 02:06 PM
Greetings from Germany
Henrik
LV since v3.1
(6,980 Views)
thanks for the reply.
Urm actually I am also not a cardiologist. What method I want to approach is, I want to build the ECG signal from the heart beat. Is it possible to do that.
The method I plan to do is;
1. use the acoustic statescope
2. amplify the heart beat using microphone
3. build the ECG signal.
If let say I cannot build it, I just want to extract the R peak location to calculate the heart rate.
(6,969 Views)
Hi anes_atica,
If you are just looking for the peaks, you can use the Peak Detection function to do so. There is more information in this thread.
Kent
(6,950 Views)
