Signal Conditioning
calibration of scxi-1112
how do i calibrate Scxi -1112 internally and externally example using fluke instrument.
can i calibrate scxi-1112 using calibration executive.
(3,289 Views)
Suresh,
I assume you will be using LabVIEW to perform the calibration (let me know if I am incorrect). The LabVIEW help for "SCXI Calibrate.vi" (Functions >> Data Acquisition >> Calibration and Configuration) describes its use for both internal and external SCXI calibrations.
Good luck with your application.
Spencer S.
(3,289 Views)
