Signal Conditioning
cant access scxi 1163r in labview
i created virtual channel for scxi 1163r in max and tested it and it worked fine. however when i tried to operate scxi 1163r in labview, it didnt work.
in labview, i tried to use the build in library for scxi 1163r which is "SCXI-1163(R) Digital Output.vi" file. it seemed to me that the problem was the sub vi which are "dio port config.vi" and "dio port write.vi". i use pcmcia daq board to connect the scxi and the chassis is scxi 1001. i also have an analog module on the chassis that connected directly to the daq board.
(3,227 Views)
I successfully ran the program, "SCXI-1163(R) Digital Output.vi" with the SCXI-1163R.
Here are the steps I followed:
1. I created a virtual channel and typed the virtual channel name in the port number control.
2. I ran the VI
3. I connected a DMM externally to channel 0 and COM (GND pin on the SCXI 1326).
4. I verified that the switch responded correctly based on the following logic:
The program states that when logic "1" is selected for a channel the switch is open between the selected channel and the COM. However that when logic "0" is selected for a channel the switch is close between the selected channel and the COM. For example in the "pattern to write" series of buttons, when a button is red it signifies a logical "1" which me
ans that channel is not connected to COM.
Steps to Try:
Please run a connectivity test on the channels of interest. If the system is returns an error code or you need clarification on the above instructions, please let me know.
Russell Blake
Applications Engineering
Director of Engineering
G Systems, www.gsystems.com
Certified LabVIEW Architect
Certified LabVIEW Embedded Systems Developer
GCentral
(3,227 Views)
