Signal Conditioning
floating ground voltage output from BNC2110
I would like to know, if anybody has idea about to make floating ground mode output voltage from DAC through BNC2110 model.
I am getting connection between real earth ground and BNC's of both core and shell, which are ground through AO.
Does it possible to get floating mode in BNC2110 model?
The switch given for Floating mode does not make difference from ground source mode.
(6,827 Views)
See this
Shreyas Hebbare
Shreyas Technologies
India
(6,816 Views)
Thanks for your reply.
I have gone through that but this does not fulfill my requirement.
Actually, I want both core and shell of the BNC should be floating from the real ground.
What I have is grounded with real ground, which  makes me impossible to design the floating voltage divider network.
If you have any other solution regarding this issue, Please let me know.
(6,810 Views)
Dataforth's DSCA41-03 takes -10/+10V in and ouptputs -10/+10V, 3kHz bandwidth, full I/O isolation.
http://www.dataforth.com/catalog/pdf/dsca40_41.pdf
-AK2DM
(6,795 Views)
