Signal Conditioning
how can i configure scxi1313 in RSE mode?
hai all,
i have connected scxi1125 with scxi1313, i want to accuring data from SCB68 analog o/p port as feed back to scxi1313,but the problem is SCB68 Analog o/p is in RSE mode but scxi1313 is accepting Differential mode i/p, so data acquition is not proper, please suggest the optimum solution.
with regards,
suresh
ATS-Blr.
Message 1 of 9
(4,565 Views)
Hi Suresh,
How are you?
The problem you mention should not arise because Differential mode can acquire both floating as well as ground referenced signals.
And an analog output signal that is generated by a DAQ card is ground referenced (AO ground of DAQ).
Which is the DAQ card you are using is it PCI or is it a PXI sitting is a combo chassis along with the mentioned SCXI 1125 module?
Regards
Dev
Message 2 of 9
(4,563 Views)
i am fine, how r u? my DAQ card is PCI6229 more over i am connecting in cascading mode,then what could be the problem, please give guidance
regards,
suresh
Message 3 of 9
(4,567 Views)
Hi Suresh,
Kindly clarify two things.
  • In your first post, you said "i want to accuring data from SCB68 analog o/p port as feed back to scxi1313",
 So, are you Multiplexing the SCXI 1125 to the same PCI 6229?
  • If it is so, how is SCB 68 connected to the PCI 6229 DAQ card?
Regards
Dev
Message 4 of 9
(4,557 Views)
Hi Suresh,
Regards
Dev
Message 5 of 9
(4,557 Views)
Hi Suresh,
Regards
Dev
Message 6 of 9
(4,557 Views)
Hi Suresh,
         So, are you Multiplexing the SCXI 1125 to the same PCI 6229 that is generating Analog output?
Regards
Dev
Message 7 of 9
(4,557 Views)
hai dev,
 As i mentioned i am going to take feedback in cascading mode, as PCI6229 have 2 connector terminals which one can be allocated to SCXI and another to SCB.
Message 8 of 9
(4,553 Views)
Hi Suresh,
I suggest cabling Connector 0 of the 6229 to the SCXI and cabling Connector 1 of the 6229 to the SCB-68.  You can then connect AO GND and your AO channel to the differential + and - inputs on your SCXI-1313.  Because, the SCXI-1313 is taking differential measurements, it will simply take out the common noise from the AO GND line and the AO channel line.
Allen
Message 9 of 9
(4,546 Views)
