Signal Conditioning
how to interface ADSP 21992 with LabVIEW?can i use ADSP 21992 with labview for data acquisition?
how to use for data acquisition using DSPs?
(3,193 Views)
Greetings,
What data are you trying to acquire from your DSP? Do you simply want to monitor Digital Output lines from your board? If so, you can use any of National Instruments M-Series, E-Series, or DIO boards.
I noticed, however, that this particular DSP has a CAN interface on it. Are you trying to acquire CAN signals?
Hope this helps, and as always reply back with any questions you may have.
Anuj D.
(3,193 Views)
thanks sir----yaa ADSP 21992 has CAN-----I want to acquire data & then using LABVIEW or VI its processing.
(3,193 Views)
