Signal Conditioning
how to realize More channels 4-20mA current loop output
Message 11 of 17
(4,994 Views)
K C wrote:
Hi Candy,
According to Ohm's law (at least at this side of the world Smiley Wink ) a current of 4-20mA through a 50Ohm resistor gives a voltage of 0.2 - 1V
Please explain your value of 10-50mV
I do not understand your second question. A accuracy of 0.3-0.4% is rather good I think for transmitters.
Message Edited by K C on 11-03-2008 08:34 AM
KC,
the the input is 50Ohms MAX . ~2Ohm < 50 Ohm ...
 I didn't take a look into the datasheet,but maybe R_in=f(Ucc,f,T,Ri_signal)
Greetings from Germany
Henrik
LV since v3.1
Message 12 of 17
(4,987 Views)
Hallo Henrik,
Maybe you are right, but most devices (sensors, transmitter, repeaters, barriers, etc)  I know with 0(4)-20mA I/O have a fixed resistance of 50 or 250Ohm.
But I am working in a small world Smiley Wink
btw. who marked a empty post as a solution ? Smiley Surprised ?
Message 13 of 17
(4,983 Views)
sorry,i don't know why it is empty,i wrote some,but can't appear.
Message 14 of 17
(4,966 Views)
about that 10mV~50mV,i mean our products(voltage signal &current signal) resistance is 50 Ohm(max),but generally is much less 50 Ohm, and 4-20mA this series across the diode voltage general is 10mV~50mV. Candy
Message 15 of 17
(4,965 Views)
As the previous user suggested you can use a TURCK IMS interface module. (some info on that here - http://www.clrwtr.com/blog.html )
You can also try an ABB/Entrelec or Weidmuller analog signal transmitter/converter (http://www.clrwtr.com/Weidmuller-Waveanalog-20LP-Signal-Conditioners.htm )
Message 16 of 17
(4,674 Views)
The Weidmuller signal conditioner link that you have listed here was moved. Please use the following link instead for Weidmuller signal conditioning products.
http://www.clrwtr.com/Weidmuller-Signal-Conditioning.htm
Message 17 of 17
(4,247 Views)
