02-19-2006 12:51 AM
Hai all,
I am Configuring SCXI 1125 and SCXI 1142 along with M-series DAQ PCI-6229, if i want to set AUTO GAIN option for my SCXI 1125, what i want to do..please suggest me the solutions
Suresh S |
02-20-2006 05:41 AM
Could you be a bit more clear?
do you mean that you want to Dynamically set/reset the range of ADC while measuring a signal?
or do you mean something else by 'AUTO GAIN'?
Regards
Dev
02-20-2006 11:53 AM
02-20-2006 09:47 PM
I second Michela's point that Gain settings are not a dynamic property once the task is started on the SCXI 1125 but would like to add one point.
your hardware does not have traditional DAQ support, hence concentrate on DAQmx Gain settings.
regards
Dev
02-20-2006 10:54 PM
Hai Micaela N & dev,
Thanks for your Suggestions, from your points shall i conclude that dynamically i cannot change the Gain Property, if i want to change, i want to Stop the Current Process then i can change with the help of Gain Property node settings. but i have a doubt my signal is going to vary from 0.1v to 20v through out the process,in this case how can i set the gain property, Expecting your suggestions.
Suresh S
02-21-2006 03:11 AM - edited 02-21-2006 03:11 AM
Hi Suresh,
You have to set gain that caters to the highest expected voltage level in your measured signal.
Are using SCXI 1327 terminal block??
if you are, a gain setting of 20 on SCXI 1125 and gain of 0.01 on SCXI 1127 which gives an input range of =/- 25V, should measure a signal of your specified range
hope this helps
Regards
Dev
Message Edited by devchander on 02-21-2006 03:16 AM
02-21-2006 10:30 AM
