Signal Conditioning
how to set the jumper for scxi 1140?
Hi, I would like to connect the SCXI1140 module to PCI 6052E.SCXI1140 is connected  to SCXI 1125 by the cable SCXI 1325 to get the data from SCXI 1125. I could not well understand the suitable configuration  for W9, W10,W11, W12, W13 and W14 jumpers in  SCXI1140. would you please help me out?
(6,505 Views)
First, can you please verify that you are using the SCXI-1352 cable and not the SCXI-1325 teminal to cascade the SCXI-1125 to the SCXI-1140. Here is a link about cascading SCXI modules and here is the link developping your particular case of cascading the SCXI-1125 to the SCXI-1140. You can see that the configuration of the jumpers depends only on your application. This link  to the User Manual of the SCXI-1140 should give you the configuration you have to make depending on your application.
I hope this will help you.
(6,485 Views)
Hello
I greatly appreciate you kind assistance.
As a matter of fact, I am a new user of NI. I have gone throught the all manual many times but I could not well underestand them and could not find the suitable jumper setting for my appliacation. I will explain my set up , would you please kindly tell me the exact setting?
Voltage floating signal from transducer is sent to the terminal box (SCXI1327) that is connected to SCXI1125.
SCXI1125 is placed in the SLOT1  SCXI chassis.
SCXI1125 is connected to the SCXI1140 with cable SCXI1352.
SCXI1140 is used to track and hold the data and send it to the PCI6052E.
Thanks in advance.
(6,478 Views)
Hi Mohammad,
Seeing your configuration, I assume you want to use analog inputs. In the manual of the SCXI-1140 module, you can find on page 2-6 and 2-7 a description on the way to configure each jumper.
jumpers.JPGThis image sum up the configuration.
 I hope this answers your question.
(6,473 Views)
