Signal Conditioning
How do I install voltage divider resistors for channels 8-31 in scb-68?
I am using an analog output card, NI 6723 and I need to attenuate the voltages from the 8-31 channel connector.  Is there a way to install voltage divider resistors for these channels in a scb-68 connector block?  The manual I have indicates it is possible, but there do not seem to be enough positions in the box for 24 pairs of resistors.
(6,011 Views)
Accepted by topic author mjgatgrc
I found a newer version of the manual online.  It seems only 2 AO channels can be conditioned in this way.  Thanks.
(5,998 Views)
