Signal Conditioning
Showing results forĀ
Search instead forĀ
Did you mean:Ā
increas write to file process speed
Dear Sir/Madam
I’m a PhD student working in smart home project and I have a problem.
I designed a labview program that control 8 multiplexer (32-channel) to acquire 256 signals, the input samples/channel = 2 , and the sample rate is 40KHz.( see the attached program)
The problem is when I add (write to file) instruction the entire process will be slower than before and for sure the signals will be in different shapes.
Please, could tell me how I can overcome this problem and increase the process speed?
Thank you for your attention in this matter
Yours faithfully
Ibrahim
(6,107 Views)
(6,099 Views)
