Signal Conditioning
is there protection on the excitation channels of the scxi-1540
Hi All,
Is there any protection built into the circuitry of the SCXI-1540 so that if the primary winding of an LVDT short circuits then the excitation from the 1540 will not be  destroyed.
kind regards
Frank Greenslade
Christchurch
New Zealand
(6,317 Views)
Accepted by topic author FRG
Hi Frank,
The SCXI-1540 is supplying the excitation, thus the same amount of excitation is provided by the module even if the LVDT shorts.  No additional current should be drawn.  Hopefully this helps!
h_baker
(6,303 Views)
