Signal Conditioning
programing for PXI-6071e with SCXI1125
Dear All,
        I have connected SCXI-1001 chassis having SCXI-1125 conditioning card and SCXI-1327 block with PXI-6071E card on PXI-8176 controller using SH1006868 cable. I have selected accessory SCB-100 for PXI-6071, as there is no option to select SH1006868. I have connected Thermocouple on terminals of SCXI-1327.
     I am new in LabView, Any one can guide me how to program. If any one have example program, it will be useful to be to start learning
Thanking you
Regards
--Vishnu
(6,534 Views)
Accepted by topic author Vkumar
I dont think you can select the cables for your accessory. Only the terminal blocks for the DAQ cards will be available on your list. Instead of the SCB-100, can you select the 1327 terminal block? To get started, labview has a number of application examples. Go to the help menu and select "find examples" then search for thermocouple. There should be examples on how to acquire voltage readings from a thermocouple, graph your data etc.  🙂
(6,463 Views)
