Signal Conditioning
maximum sampling rate of one PCI 6250 with three SCXI-1102C
What is the maximum sampling rate per channel can I get at using 96 channels of three SCXI-1102C (333kHz) modules with one PCI 6250 (1MHz) controller?
(5,907 Views)
Hi Raynor,
This is available programmatically and will give you an exact answer for every hardware combination you can configure. All you need to do is set up the task channels and poll the driver the maximum sampling rate with a Timing property node: DAQmx Timing » Sample Clock » Maximum Rate.
Can I Programmatically Determine the Maximum Sampling Rate of My DAQ Card?
http://digital.ni.com/public.nsf/allkb/104E42830B2E2CE486256DBE005E68E4?OpenDocument
Message Edited by Joe F. on 04-17-2008 01:44 PM
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(5,903 Views)
