Signal Conditioning
how should i do?when i use the sc2345 for analog signal acquired!
please help me!
I have to use the sc2345+NI6221 for analog signal acquired. but i don't have a analog input module such as SCC-AIXX.
So I want to pass the signal to the DAQ device. how should i do to connect the wire on the sc2345?
how can I use the sc2345 for a pass connector?
Thank you very much and look forward to your reply...
(6,308 Views)
Accepted by topic author romeo2xiao
What kind of signal do you want to acquire?
If it does not need any conditioning, then, you can connect the signal to 6221 with a terminal block such as SCB-68.
NISH AE Haiping.Fei
(6,275 Views)
