Home
Community
Discussion Forums
Most Active Hardware Boards
Signal Conditioning
Topic
Signal Conditioning
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
how should i do?when i use the sc2345 for analog signal acquired!
romeo2xiao
04-17-2008
09:48 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
please help me!
I have to use the sc2345+NI6221 for analog signal acquired. but i don't have a analog input module such as SCC-AIXX.
So I want to pass the signal to the DAQ device. how should i do to connect the wire on the sc2345?
how can I use the sc2345 for a pass connector?
Thank you very much and look forward to your reply...
Go to Solution.
0
Kudos
Message
1
of 2
(6,314 Views)
Reply
Accepted by
romeo2xiao
回复: how should i do?when i use the sc2345 for analog signal acquired!
Roger.Fei
04-24-2008
03:28 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
What kind of signal do you want to acquire?
If it does not need any conditioning, then, you can connect the signal to 6221 with a terminal block such as SCB-68.
NISH AE Haiping.Fei
0
Kudos
Message
2
of 2
(6,281 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
