Signal Conditioning
noise of frequency 10MHz to 40GHz, is it acceptable?
hai
Am using SCXI 1125. The extension wire to get thermocouple will pass through noise of frequency 10MHz to 40GHz. Will this cause any effect the measurement i need to have an accuracy of 0.5deg C
Thanx for any answeres
Arun
(3,035 Views)
Arun,
The SCXI-1125 can be configured to have either a 4 Hz or a 10 kHz filter to eliminate noise in the signal. With this filter the noise you are experiencing should not affect your measurements.
You can read more about the SCXI-1125 and filters in the user manual:
http://digital.ni.com/manuals.nsf/websearch/85C7726245BE7391862567BE0056BAFD?OpenDocument&node=132100_US
-Sal
(3,035 Views)
