Signal Conditioning
passage LV 5.0 à LV 6.0.2
Problems at the time of the passage to labView 6.0.2 with a programme
of data acquisition carried out with labView 5.
Example of error with the loading of the VIs (in French):
ACQ.VI
Face-avant
- Daq setup.Limits utilise une coercition de gamme,
qui ne s'applique désormais qu'aux données d'entrée ;
les valeurs ne seront pas contraintes lors de leur passage à un sous-VI.
Pour contraindre les données transmises,
utilisez la fonction Dans la gamme et contraint.
Error of execution:
Error -10240 occured at Al Group Config
Possible Reasons:
NI-DAQ LV: The driver interface could not locate or open the driver.
Material used:
SCXI-1000DC
SCXI-1200
SCXI-1302
I installed the driver of the SCXI-1200.
The data acquis
ition functions correctly with MAX V2.0, NI-DAQ V6.8.1f1
Can you help me?
(2,997 Views)
When you upgraded to LabVIEW 6.0.2 Did you upgrade you version of NI-DAQ? Your hardware is still supported under our most recent driver 6.9.3. By running the NI-DAQ installer please verify the support for LabVIEW 6.0.2 is installed.
Otherwise please refer to the knowledgebase
http://digital.ni.com/public.nsf/websearch/E6D9288AE28A78718625658B0003F699?OpenDocument
for information on getting VIs built in LabVIEW 5.1 with older versions of DAQ to work in 6.x without getting error -10240.
Hope this helps.
Kevin R
(2,997 Views)
