Signal Conditioning
How do I wire Load Cell to AT-MIO-16XE-50?
I am trying to wire load cell to AT-MIO-16XE-50. Load cell consists of +in, -in, +out, and -out. Excitation Volatage is 15.0V.
According to AT-MIO-16XE-50 manual, AOGND is not available in it. I hope that anyone will be able to give me a pin mapping. (The load cell is about to connected to AT-MIO-16XE-50 directly.)
(3,393 Views)
The pinout of the card is found on page 4-2 of the manual (AOGND is pin 55). In any case, the card is not designed to work with load cells. There are other modules that are designed for load cells - check the following:
Resources: Keywords Search: load cell measure
Modules: Keywords Search: load cell
RamziH.
Message Edited by Molly K on 02-19-2005 12:07 AM
(3,394 Views)
In my lab, the load cell is connected to the SCB-68. I use the the NRSE mode. So I don't use the GND on it. But I am not sure if I made a correct signal conection?
Can somebody tell me if the load cell signal is a grounded signal?
Thanks you very much in advance?
(3,393 Views)
