Signal Conditioning
pins for signal inputs in SC-2345
I'm using SC-2345 with PXI-6220 to acquire two otuput signals from a generator, one which is modified through a circuit and another direct from the signal generator.
currently, i could only obtain the former signal with socket j4 and pins number 1 and 2.
May I know how to do the connections with wires to get the two signals?
yam
(3,200 Views)
yhow,
Please take a look at the SC-2345/2350 Carrier User Manual.  As shown in Table B-1 on page B-2, pins 1 and 2 on J4 correspond to AI(X) and No Connect.  This would not give you the proper connection to measure your signal.
If you are trying to read two channels of analog input and you need some degree of signal conditioning, I would definitely recommend that you use one of our SCC-AI modules.  If all you need is a direct connection to the analog channels of your 6220, you should use an SCC-FT01 module to provide access to the necessary pins.  As you can see from the product page for the FT01, these modules are very inexpensive and provide a solid interface for connecting your signals.  If you want to do referenced single ended (RSE) measurements, you can use one FT01 to read both of your input channels.  If you want to take differential measurements, you would need to use two FT01 modules.
I would not recommend inserting wires directly into the sockets on the SC-2345, but if you absolutely have to do this, you can use the table that I previously mentioned to determine the proper connections.
(3,182 Views)
