Signal Conditioning
pool temperature measurements
I am looking for a low cost solution to measure and acquire (Windows XP)my pool and hot tub temperatures, any suggestions would be greatly appreciated.
(3,387 Views)
How about a temperature to frequency converter and use the Printerport or the stereo sound input to read two channels?
just as starting points:
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/2025/ln/en
http://www.elecdesign.com/Articles/ArticleID/4563/4563.html
and
http://www.analog.com/library/analogDialogue/archives/30-1/digital.html
Greetings from Germany
Henrik
LV since v3.1
(3,387 Views)
Good answer, Henrik! That is definitely a possible solution.
Another solution may be to use a low-cost National Instruments DAQ board to acquire a signal from a temperature sensor (like a thermistor or RTD). A PCI DAQ board such as the PCI-6013 may prove to be a good solution for you. A link to the product page for this board is below:
PCI-6013
I hope this helps!
Ken S.
Applications Engineering
(3,387 Views)
