Thank you for contacting National Instruments.  Yes, the SCXI 1100 can handle a current input of 10 mA.  The module is designed to be used for current inputs ranging from 0-20 mA or voltage inputs ranging from negative to positive 10 V.
This information, as well as other specifications for the SCXI 1100 can be found in the product manual for that device, located at:
SCXI 1100 User Manual
http://digital.ni.com/manuals.nsf/webAdvsearch/0790D3C92CF4B16E8625665E00712865?OpenDocument&vid=niwc&node=132100_US
The current input specification is mentioned in the "About This Manual" section.
Let me know if you have any additional questions on this issue.
Scott R.
	Scott Romine
Course Development Engineer
