Signal Conditioning
problem with scxi 1200 while acquiring data from other modules
Hi
We have an scxi system, with
scxi 1000 chassis
scxi 1200,
scxi 1100 and
scxi 1121 modules
We are making settings with max. All modules are seen at max. We havent any
installation problem.
We connected scxi 1000 chassis with LPT1 with parallel cable. Slot order is
1. SCXI 1200
2. SCXI 1100
3. SCXI 1121
We are trying to get data by thermocouple demonstration unit over scxi 1100
but we didnt get any response. Also we couldnt get any response from scxi 1121.
when we run test panel displayed data is continously decreasing.
we tested scxi 1200 with 50pin cable with voltage inputs and we can get response from channels and when we run scxi 1200 run test panel we have seen all
data.
But we couldn't
get any response from other modules with scxi 1200
I think scxi 1200 is couldn get data from other modules, what might be reason of the problem?
(Also buy scxi power vi we checked whether chassis' power is on and modules are verified.)
(3,089 Views)
Exactly how are you trying to get TC readings from the 1100? LabVIEW? What VIs are you using? How are you calling the channel names?
Mark
(3,089 Views)
