Home
Community
Discussion Forums
Most Active Hardware Boards
Signal Conditioning
Topic
Signal Conditioning
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
reading the cjc voltage with ni4351 and tbx-68t
kenlimch
Member
05-12-2002
08:21 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I'm having problem reading the cjc voltage on the ic sensor. It was fine initially but something just happened and the value sticks to a default of 0 and any other previous values read by the VI for thermocouple. Please advise.
0
Kudos
Message
1
of 2
(3,384 Views)
Reply
Re: reading the cjc voltage with ni4351 and tbx-68t
Filipe A.
Active Participant
05-14-2002
09:27 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hello;
If the IC waas properly working before and sudenly stop working, that pretty much indicates a hardware failure on the TBX device.
Regards
Filipe A.
Kudos
Message
2
of 2
(3,384 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
