Signal Conditioning
scb-68 board drawing
Does anyone have dimensional drawing of the circuit board inside the SCB-68?  Thanks.
(7,858 Views)
There are official dimensional drawings available for this device.  If you go to the NI SCB-68 product page and select Resources » Dimension Drawings you'll be directed to this page: Dimensional Drawing for SCB-68.
Hope this helps!
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(7,857 Views)
Thanks, but that drawing (at least the .pdf) shows just the outside of the box, not the circuit board.
(7,853 Views)
Accepted by Gris
Sorry, I misread your post.  I believe this is what you are looking for:
Seth B.
(7,851 Views)
Fantastic!  Thank you.
(7,847 Views)
Can anyone give me the Pin Configuration of SCB68.... i have to connect it with Rseries DAQ..... i not need SCB68 with R series which was given already... i wan to know seperate Pin Configuration of SCB 68
(7,697 Views)
Hello Alieas,
If you look at this article: https://www.ni.com/en/support/documentation/cable-accessory-guide/daq-multifunction-i-o-cable-access... it gives links to all the different SCB 68 reference labels and pinouts. I hope this helps!
-Nathan H
Software Developer
(7,684 Views)
