Signal Conditioning
scxi-1200 serial installation
hi,
i have an old scxi-1200 fitted into a scxi-2000 chassis..
i have connected it to my pc via serial cable, and have followed this tutorial: [broken link removed]
and is all good until i hit the 'select hardware from list' part.... the scxi-1200 is not listed, like it is on the tutorial.
can anyone help?
thanks,
daniel
(5,182 Views)
Hello Daniel,
I suggest you take a look at our SCXI Troubleshooting Resource. This page can help you determine if your system is configured correctly.
Can you provide some more information about the problem you are having? I assume by your post that you are referring to step 5 of the document you have linked. Is this correct? When you say that the SCXI-1200 is not listed, do you mean that there is no entry for Data Acquisition Devices in the Hardware Types window? Or do you mean that the list of National Instruments devices populates and the SCXI-1200 is not shown in the Models window?
Matt Anderson
Hardware Services Marketing Manager
(5,165 Views)
Hi Matt,
Thanks for your reply.
Yeah i have trouble with step 5. After selecting 'Data Acquition Devices', there is no 'SCXI-1200' as depicted on the picture (but there are other NI devices to choose from). Same thing with step 7 of the SCXI Troubleshooting resource.
I have the NI Developer pack installed and registered.
We are waiting on a quote on the SCXI-1349 connector, so we can use our PXI device to drive the SCXI rack. So this problem may not occur afterwards.
Dan
(5,157 Views)
Hello Dan,
If you note the SCXI Troubleshooting Resource we discussed, you will see that step 5 includes the following note:
" If Data Acquisition Devices does not show up, it is likely that you have not installed NI-DAQ correctly."
This leads me to ask, do you have NI-DAQ installed on your machine? If so, what version do you have? You should be able to tell if you driver supports the SCXI-1200 by reading the Read Me file that accompanies the driver. The SCXI-1200 is a legacy device and is only supported by the NI-DAQ driver, not NI-DAQmx. Additionally, the device is not supported in Windows XP or Windows 2000, which may impact your application.
I hope this helps.
Matt Anderson
(5,145 Views)
Is there any way I can configure my scxi-1200 with a Windows XP Os?  From the website, http://www.ni.com/support/scxi/remote/sftcnfg.htm
it  seems only support by  up to Windows 98 and NT.
Thank you
(4,383 Views)
Hi Matt,
So, I checked the posted link, and it states that the scxi-1200 is not supported by XP even I install a DAQ6.9.3.  Is there any other way I can make it run in my XP system?
Thank you.
(4,377 Views)
Good morning Hsien,
It appears that you would like to communicate with a SCXI chassis using Windows XP.  Unfortunately, as you noted from the webpage, the SCXI-1200 is not supported with Windows XP.  There are other options however.  You could use a SCXI-1600 to control the chassis, or you could use a Multifunction M-series DAQ card, such as the PCI-6251, with a SCXI-1349 to communicate to the chassis.  The SCXI 1349 plugs into the back of one of your SCXI input devices and cables back to your Multifunction DAQ card to your PC.
Best,
Adam
Academic Product Manager
National Intruments
(4,355 Views)
