05-12-2010 08:25 AM
Hallo all, I have a doubt.
In the past, I'm sure I have seen a document (on NI website or Devzone, but I can't find it now easily), where I read that it is necessary to choose different versions of the SCXI-1349 module, when you use this adapter, connected by a 68 pin cable, with E-Series DAQ or M-Series DAQ. Is it true?
If that is the case, which is the association between the different types of DAQ Board and different versions of the Adapter?
And how can I recognize the version of the adapters I have bought in the past? Searching in some way with the S/N, or watching, for example, a label on the product?
Thank you for your help!
Stefano
Solved! Go to Solution.
05-13-2010
04:29 AM
- last edited on
10-14-2025
03:52 PM
by
Content Cleaner
Hi Stefano.
SCXI-1349 is fully compatible both with E-series DAQ and with M-series DAQ.
If you use E-Series DAQ you must connect the card to the connector with SH-68-68-EP cable, indeed you must use SHC-68-68-EPM cable with M-Series DAQ.
For many infos you can chek the following links:
http://digital.ni.com/public.nsf/allkb/7644E54DD42D4A45862570A4007E1669
Bye!
05-26-2010
05:29 PM
- last edited on
10-14-2025
03:53 PM
by
Content Cleaner
Hi Stefano,
Actually, there was an issue with older revisions of the SCXI-1349 + M Series + parallel mode. This might be the document you were looking for: SCXI Modules Do Not Work When Used with M Series in Parallel Mode. If you're not using parallel mode, this should not affect you.
Brad
05-27-2010 02:07 AM
Hi Brad,
I'm sure that this document, is the same mentioned in my first mail.
Thanks for your cooperation!
Stefano
