Signal Conditioning
scxi-1349 versions
Hallo all, I have a doubt.
In the past, I'm sure I have seen a document (on NI website or Devzone, but I can't find it now easily), where I read that it is necessary to choose different versions of the SCXI-1349 module, when you use this adapter, connected by a 68 pin cable, with E-Series DAQ or M-Series DAQ. Is it true?
If that is the case, which is the association between the different types of DAQ Board and different versions of the Adapter?
And how can I recognize the version of the adapters I have bought in the past? Searching in some way with the S/N, or watching, for example, a label on the product?
Thank you for your help!
Stefano
(6,753 Views)
Accepted by topic author stefano_m
Hi Stefano.
SCXI-1349 is fully compatible both with E-series DAQ and with M-series DAQ.
If you use E-Series DAQ you must connect the card to the connector with SH-68-68-EP cable, indeed you must use SHC-68-68-EPM cable with M-Series DAQ.
For many infos you can chek the following links:
http://digital.ni.com/public.nsf/allkb/7644E54DD42D4A45862570A4007E1669
https://www.ni.com/en/support/documentation/supplemental/18/scxi-1346-and-scxi-1349-breakout-pin-tra...
Bye!
MarcoMar
National Instruments Italy
(6,737 Views)
Hi Stefano,
Actually, there was an issue with older revisions of the SCXI-1349 + M Series + parallel mode. This might be the document you were looking for: SCXI Modules Do Not Work When Used with M Series in Parallel Mode. If you're not using parallel mode, this should not affect you.
Brad
Brad Keryan
NI R&D
(6,671 Views)
Hi Brad,
I'm sure that this document, is the same mentioned in my first mail.
Thanks for your cooperation!
Stefano
(6,663 Views)
