Signal Conditioning
scxi 1531
Hi
I am using NI equipment: Chassis SCXI-1001, with a set of modules including SCXI-1531. My question is: How can I achieve the signal conditioning for ICP accelerometer type with DAQmax for programmable current, gain and filter in each channel?. Now I am using an external ICP SENSOR SIGNAL CONDITIONER to provide excitation for the sensor and to adjust its gain. The other problem is: if I need to use more than one sensor I have buy its signal conditioner and is very expensive. I found that the SCXI-1531 module can itself provide this parameters. Send me your feedback about how can I do it.
I attach my VI developed in LABview 8.2
Best regards
Dimas
(6,778 Views)
Have you take a look at the manual chapter 2-2  from page 26 for signal conditionning ?
Also you can have look here :
Measuring Vibration Using an IEPE Accelerometer
measure with a SCXI-1531
How Can I Modify the Properties For SCXI 1530/1531
For scxi calibration we have the vi's for it :
Hope this helps,
Regards.
Message Edité par Steve Mohamed le 04-21-2009 03:47 PM
Steve M.
(6,739 Views)
Hi
Thanks to answer my question. I read the scxi-1531 manual as you suggest me and I tried to follow the example that you sent. But in this link  How Can I Modify the Properties For SCXI 1530/1531 I couldn't see the picture. I think there are problem with displaying the picture. Could you send me again.
Thank you
Best regards
Dimas
(6,666 Views)
