 PL32
			PL32
			05-07-2009 09:25 AM
What is the breadboard pin spacing on an SCB-68 breakout board? And what would be a good part number for adding additional screw terminals to the breadboard area?
Solved! Go to Solution.
 AnalogKid2Digit
			AnalogKid2Digit05-07-2009 10:12 AM
PL32:
0.100" spacing, here is an example of terminal blocks, there are many other different manufacturers. Just be sure the holes in the breadboard area are large enough to accomodate the pin of the terminal block.
http://www.alliedelec.com/Catalog/pf.aspx?FN=300.pdf
-AK2DM
05-07-2009 10:57 AM
