Signal Conditioning
breadboard pin spacing on SCB-68
What is the breadboard pin spacing on an SCB-68 breakout board?  And what would be a good part number for adding additional screw terminals to the breadboard area?
(6,758 Views)
Accepted by PL32
PL32:
0.100" spacing, here is an example of terminal blocks, there are many other different manufacturers. Just be sure the holes in the breadboard area are large enough to accomodate the pin of the terminal block.
http://www.alliedelec.com/Catalog/pf.aspx?FN=300.pdf
-AK2DM
(6,756 Views)
Many Thanks for the help.
(6,753 Views)
