03-02-2010 11:16 AM
Hello.
I am using de SCXI-1521b to measure strain gauge of 120 ohm. Because the strain gauges are inside a column, i have a important resistance due the wire. I have reading 125-127 ohm in the conection whit yhe SCXI module. Because of this, i can't read any value. I had tried changing the imput range and the other parameters but nothing happen.
Why can i do for this?
PD: sorry my English, i speak spanish but in this language are more people and information.
Thank!
03-03-2010 10:00 AM
Hi mrozic,
When you are at the task configuration(where you configure the range), there is a Lead Resistance field. In this field you can input the resistance of the wires and the software will compensate this resistance.
If you have doubts, let me know.
